It is currently Sat Jul 19, 2025 4:00 pm
PostPosted: Mon Oct 15, 2007 3:34 pm
I have been using a waterbased stain made by the Clearwater company for my hand rubbed sunbursts but it apears that they have closed up shop and the stuff is not available any longer. So I am looking for something else. I like to use the stewmac colors in the little bottles but need some way the reduce them and allow me to hand apply them. I have tried thinning with water and alcohol with less than desirable results. I use Nitro lacquer as a top coat but don't want to spray the color on. So since tru-oil is compatable with nitro, I am thinking about using it colored with the stain and rubbing that onto the wood. Has anyone else tried this? Also who is a good choice for a tru-oil supplier? TIA, John
PostPosted: Tue Oct 16, 2007 1:49 am
Last Name: Ball
I have tried Tru Oil as a staining medium.  The problem with it is that it adds a yellowish color of its own that is noticeable in the color of the resulting stain.  If you're doing staining a warm color, it is probably no big deal, but it does add some yellow to the final color.
PostPosted: Tue Oct 16, 2007 2:08 am
Shellac would be another option.
John, if you don't mind me asking, why do you not like spraying the color coats? I like the even color that this gives.
PostPosted: Tue Oct 16, 2007 2:51 am
[QUOTE=BarryDaniels] Shellac would be another option.
John, if you don't mind me asking, why do you not like spraying the color coats? I like the even color that this gives.[/QUOTE]
I like the uneveness that rubbing gives and it allows more of the wood character to come thru as it absorbs the stain at different rates in different areas. I know that some want things nice and even but I like my results. The reason I want some sort of medium though is to keep the staining very subtle and violin like.
Thanks for your ideas guys.
PostPosted: Tue Oct 16, 2007 8:57 am
Stewmac gets their dyes from homestead finishing. Check their site and see what else they have as dyes and mediums. Great source of hand tempered shellac too.
PostPosted: Tue Oct 16, 2007 10:29 am
Tru oil can be purchased at your local gun shop, Walmart sporting goods section, on-line at Midway USA, or Stewmac.
